lostsoul
2014 vett or 2015 stang..
I need a definitive answer to this...
The p1-sc is suppose to be 50 state smog legal. Now, you can send the unit in to get converted to a d1sc. Does anyone know for SURE that you can still pass smog. Since they give you the same housing with the carb plate on it. By looks it should be ok.. But since the sc is almost the same and power doesn't really kick on till 3k+ then can I assume with a good tune that I will still pass smog even in this shitty state?
