Well.. this was fun.....not
I got the new ebay filter and it looks like above. the screen seems to be the same and not hard steel mesh like I was cutting my fingers with.. but it does seem stronger. The seller told me its good up to 30psi..
Since then I have been trying to setup a time to hit a dyno and do before and after test.. but everyone seems to be busy and not much play time. So I figured out that I can at least do a little temp test. The boost, a/f, hp will have to wait later. Basically, I wanted to do a test going down the same road at the same speed without kicking on boost or my meth injection.. everything pretty much the same around the same time.
1) So I started by leaving everything as is and warmed up the car. took it to the back street and stated the log. The Ambi temp is very wrong.. it was 101 here, not 77. Dont know if the out side temp thing works at all.
2) As you see in the first few lines of my log I start down the street with IAT= 131deg
3) Next section is a over a minute of driving @ 30mph(thing is set for mps for some reason) then ended the log
4) Stopped the log went to the house and swapped the intake for the mini mesh and left for the back road.
5) Because I stopped the car as you can see the starting IAT is higher because of heat soak. It takes about 2 minutes to get to the back road, but this is when I noticed something was not right. Even with that 2 minute of driving the temps didnt drop like I thought it would..
6) Got back to the street and stated it with IAT at 141deg.. From there you can see I did about the same time of driving and speed..
Conclusion:
With big ass stock Anderson filter over hot headers = 131-129 = 2deg reduction
With mini mesh filter = 141-138= 3 deg reduction
Sooooooooo someone tell me wtf. I know 30 mph is not much but hell I thought not having the air filter over the headers alone would have made a difference. Its almost like no matter where the filter is in the engine compartment, the air "pocket" temp is about the same. Maybe the air vol changed, but temp doesnt seem to change. Disappointing for sure. Later I will test for boost and hp change.. but I dont see how.. I'm so full of fail... ahhh
First, get away from the plastidip. I know it's already been said, but you probably should throw it away entirely. J/K.
The result was the helical cut gears they now offer as an option. If you have that choice, jump on it. It is a much better sounding blower. Quiet at idle with less gear rattle (which is normal, BTW).
Sent from my Galaxy Nexus using Tapatalk 2
Two questions?
What hood do you have?
What grill as well.....
It's loud... I can promise you that!With the p1 and my mondo I like the sound.. I cant wait to hear what its like with the d1.
