procharger anderson power pipe
mac10chap
The bouncy tits guy...
houston, tx
i think that is what it requires. I dont think it will fit with a stock hood. Thats why I havent upgraded my POS plastic intake pipe.
Marc s
NASA AIX
Auburn, WA
You have to have a Cowl hood.
I find it hard to believe that Anderson's intake will makes 30 HP over the stock Procharger piece. I would like to see some flow numbers on both before I spent the money. Now, if it is sealed to the cowl hood, that would be different.
Alter Ego Trip
Pot Stirring Aficianado
White room with padded walls
From all the research I have done, it appears it does very little without a lot of supporting mods. With cams and longtubes it gained a couple psi, but on a mostly stock block it appears to not improve on much of anything.
My tuner actually recommended not using it. Here's what he had to say about it. "Oddly, I don’t know if a powerpipe is worth much, and it places the bpv return closer to the maf which is bad"
lostsoul
2014 vett or 2015 stang..
Gay Area
I was shopping with the wife. Trust me I would rather be home on the forums.
The power pipe will fit under stick hood, cowl would be best and there is a good chance you will semi wrinkle the filer but it's not that bad if you take time and make room. You can look on my thread fir pictures of how I have my setup. As for power I never really tested befire and after. Normally when I pay for 500 buck tunes it with a few items done.
mustangflanagan
south jersey
I noticed you are running 14 psi what size pully you running because i am running a 3.70 pulley and make 11 psi
