Procharger F1X blower
JPO8GT
USA
Any one on here have one or know any one with this newer Procharger blower?
By next season i am looking at going to a race blower most likely a YSi because it will bolt right on my existing bracket.
But the specs on this newer one from Procharger is tempting.
From what i read it is underrated at max 1300 crank hp when looking at its 2000 cfm rating it seems it would be rated at higher max hp. YSi is rated at 1200 max crank hp and 1600 cfm.
This thing should easily make 1000 rwhp without breaking a sweat or the need to overspin.
Bob_Kurgan
the F1x is not a new blower, its been out for over a yr.. the blower would NOT suit your combo well, as it moves TOO much air and will start to super heat it... we've also done quite a bit of testing with the YSi vs the Novi2200 and see alot of the same issues..
JPO8GT
USA
It was the first time i seen the blower thought it was newer.
Makes sense more air isn't always good if motor can't efficiently exhale the additional air.
Darn that rules out putting a blower on bigger than my motor lol.
Sactown
Sactown
Sacramento, CA
I have the full F1R race kit for sale with a bunch of custom fab work done to it just an FYI
JPO8GT
USA
Thanks but i plan on staying paxton / vortech .
wazslow
Blower is way underated. Lol. Sean Ashe went 197mph in the 1/4 with an F1X, takes way more than 1300 hp to do that.
JPO8GT
USA
Yep its a full throttle balls to the wall race blower. wonder why it stayed in the f1 category i thought f1 was pro c's entry level race blowers. Probably something to do with impeller size truly shit i don't know or need to know about.
wazslow
It was basically a cheater blower made for x275 drag radial racing.
JPO8GT
USA
Ok maybe similar to the novi 2500 blower. If i swap to another blower it will be ysi its the simplest option for me. The ysi likes to be spun hard the ysi has a 3.45:1step up ratio where the novi has s 3.6:1.
In time well go there still enjoying the novi 2200 pretty killer blower lays some killer power down! I never expected it to put 900 to tire down but with Kurgans help it did. A well setup Novi 2200 is nothing to complain about at all!
Sent from my DROID4 using Tapatalk 2
