Procharger p1sc kit for sale
Status
Not open for further replies.
05sonic4.6
Central NJ
I've decided to part ways with my procharger kit and go a different route for my build its the only reason it's for sale. What your looking at is a p1sc high output kit. It has an 8 rib belt setup with a 3.70 pulley that makes 10 psi at 6k, I had painted all the piping black and could use another coat being it got a little scratched on the way out otherwise all pipes are in good shape, the head unit is in great shape no shaft play of any kind never gave me an issue. The belt is only a few months old and is in good shape. You get everything need to bolt it on, all clamps and bolts included. This is basically a tuner kit you'll need to purchase injectors, a fuel pump, a maf or Mafia and most important a Lito tune��
Kit also comes with two crank pulleys, one for the stock harmonic balancer with the longer bolt and the other is for an ati dampener.
$2500 plus ship takes it
05sonic4.6
Central NJ
I never had it on a dyno cause I had Lito remote tune it, but they typically make between 430-450 at the wheels with this setup.
05sonic4.6
Central NJ
Bump...forgot to add kit comes with two bottles of procharger fluid and procharger coolant resivoir.
Status
