Installed a raptor dual stage shift light in my auto recently. I wanted it for the launch mode at the track. Easier to set my rpms with a light than my ears. Launching at the proper rpm is a must against the pro tree in regards to getting a great RT.
My issue is since installing this light I am getting some weird gremlins. First when I go to put the car in gear, at times it will hesistate a second initializing the gear then it jerks the car as it goes into gear. Imagine a bad u joints...but its not the them or the tranny. Both are in perfect running order. The other issue is I noticed the speedo will flicker up to 10-15 mph right when I start to take off such as from a stoplight when the car is already in gear. It also does this right before I get the jerking motion (flicker the speedo). I really think it has something to do with the vehicle speed signal wire. I followed raptors alternate wiring instructions for the pcm and not to the coil.
Has anybody ever hooked up a raptor light with an auto trans here? Anybody ever have an issue like this? Again I have the dual stage light it has 4 wires to hook up. The single stage only has 3 wires so its a different wiring setup.
http://www.raptorperformance.com/pages/raptor-shift-light-install-mustang-2005-2010-4-6l-5-4l-v8
