Replaced Halogen Headlights with LED's
pkonchar1
After I did that, when I turn on my high beams, it switches to low beams and vice versa, when on low beams, the lights become high beams. I've searched to death on this and cannot find a solution. Have any of you run in to this before and know how to resolve it?
TIA,
Paul
2006 Ford Mustang GT....
GriffX
Production error? Otherwise they should work I guess. Is there an easy way to switch the pins in the LED connector? I would not modify the OEM harness, for emergency I have a pair of H13 in the car.
pkonchar1
Do you think if I take them out, rotate 180 degrees and plug them back in they'll work? What are you using?
AHaze
Edmonton, AB
Most of those LED headlights are a generic bulb and heat sink that gets installed in different bases. I'd venture a guess the base needs to be clocked 180 degrees.
