May 19, 2014 #1 I iwisefox Junior Member Joined Apr 12, 2014 Posts 28 Reaction score 0 Where do you wire the electrical wires for the LED light? I am not getting a 12V power source anywhere in the gauge clusters. Does it not need one?
May 19, 2014 #2 LAllison20 Senior Member Joined Jul 3, 2009 Posts 1,677 Reaction score 1 Location Chesapeake, VA I ran a wire from the junction box on the passenger side have have it powering my wideband and boost gauge.
May 19, 2014 #3 I iwisefox Junior Member Joined Apr 12, 2014 Posts 28 Reaction score 0 I'll look into that, currently running into vacuum line problem. The supplied T line doesn't fit.
May 19, 2014 #4 skwerl tree hugger Joined Aug 6, 2011 Posts 16,334 Reaction score 1,313 Location central Florida The background light in the gauge? You can just tap into your dash light wiring harness depending on where your gauge is located. That way it comes on with all the other dash lights and brightness is controlled by the dimmer switch.
May 20, 2014 #5 95ragtop Senior Member Joined Sep 3, 2008 Posts 938 Reaction score 18 Location Fayetteville, NC I used the wires where you turn on your headlights.
May 21, 2014 #6 I iwisefox Junior Member Joined Apr 12, 2014 Posts 28 Reaction score 0 Thanks for all the replies. I had it wired into the headlights when they come on, off the junction box as LAllison20 mentioned. Thanks!
