Roush s/c install/knicked radiator
5tangiac.0
Houston, TX
I knicked the radiator somehow. I am talking pin hole size. Thoughts? Anyone successfully repaired one?
Also how can I torque the crank bolt down to spec after the ati install with an automatic.
5tangiac.0
Houston, TX
Buying a new radiator. Any ideas on how to stop the motor from turning over when torqueing the crank bolt?
JUSTA3V
Moar Throttle!
Queen Creek AZ
Drivers side of block at the back where it connects to the tranny.
There is a rubber plug. Pull it and jam a screwdriver in there against the flywheel / flexplate
5tangiac.0
Houston, TX
Will try that tomorrow. Thanks! Wasted half of today trying to find a longer bolt for the ati install. Wound up buying all 3' of all thread for $50
