roush short throw...
donken99
Canada
Hi, just looking for others experiences with the roush shifter ... I have a 2010 Mustang GT and just had the roush short throw shifter installed.
So far have noticed:
1) A LOT of road and engine noise coming through. I check under the console and the rubber boot and foam insulation is there.
2) Stick doesn`t center while in neutral.
Is this normal. Had it installed by a Ford & Roush dealer so I assume it was done correctly.
Any ideas, thanks.
Boorail85
I had one in my 06 gt. I dont know if there is a difference between the 05-09 and the '10.
I loved it. I didn't notice any additional noise compared to the factory piece, and it centered in neutral just fine. It felt 100x better than factory. Much shorter and felt very firm. It was a bit 'notchy' so I had to give a little more force when shifting, but overall I like it.
I didn't have any other brands so nothing to compare it to except the factory.
Dave
I do get a lot of whining through mine, but it centers fine and shifts great, most of the time. When it's cold it doesn't want to go into gear, my only complaint.
CaliStang
sofla
me and cmk have the same problem after 20minutes or so of driving the car neutral gets real sloppy and doesnt spring back? downshifting also sucks? call your dealer and tell them to call roush you got a bad shifter from a bad batch and roush will ship your installer a new one in return. hope this helps good luck.
CMK720
SoFla
x2 I can't wait to get the new one because the one me and ^him have sucks balls.
donken99
Canada
I called Roush customer service. They said the shifter need 2-3k miles on it to break it in. If it still doesn't center then call the dealer and have it replaced. How long have you had yours? Thanks for the replies.
CMK720
SoFla
2-3k miles for break in wtf?! I have mine in for about 500+/- miles and to be honest I hate every thing about it. Maybe once I get the new one things will change. I was told it's supposed to spring back regardless. I'll keep ya updated.
