fast Ed
Ed: Are you able to confirm the bore diameter of 1.063"? I'm using it to calculate hydraulic force to compare caliper options.
It looks like the above linked BMC is only for 2012-2014 models, but the cylinder diameter is the same across S197 MYs.
Sorry, the Ford parts catalogue nor the service manual are showing the m/cyl bore diameter. The Dorman listing shows the correct OE numbers, the 2010-2013 cylinders all change to the same Ford number from 2014 which is DR3Z 2140 A.
cheers
Ed
