Saleen series VI supercharger
itsmetj87
Hey guys so I recently bought a series VI super charger kit from a friend of mine who wrecked his car however some small but important pieces are missing was wondering if anyone can help me out these are the pieces I need!
-06-2002-c11237 waterpump bracket spacer (x2)
-06-1704-B12563 harness 05-09 mustang ACT connector
-06-2003-C09925 water Tube
-00-1604-C099580 Idler pulley, 76mm Guided
-06-1604-C09936 Alt pulley
-06-2001-C14002 Recovery tank bracket
-06-2003-C143800 Heater hose lower
EBABlacknChrome
Michigan
So I have the recovery tank bracket, and the 76mm pulley. I also have number for the guys in Detroit that will have all the remaining part you need. They bought all the saleen stock from the Troy plant when it closed. You are going to want to use your stock 90mm smooth pulley. 76mm will be problem. I will pm you his number.
redfirepearlgt
If you find yourself in need of a bypass valve vacuum controller, and/or the shaft/flap let me know. I have most of that rebuild kit from when I was having issues with my VI series sticking in bypass. What I do not have is the actuator (which is what got broken and is not sold sep) that attaches the vacuum controller to the shaft. Send me a PM.
RLF9409
My blood runs Ford blue!
Ramstein, GE
I know this is super old but any chance still have the shaft and flap?
