Separate clutch reservoir
DTL
SoCal
I've got a Wilwood resevoir sitting in my garage that I've been contemplating using to divorce the clutch fluid from the brake, but I haven't completed it yet. There are 2 things holding me up right now:
1) The Wilwood resevoir is pretty tall. It's going to be a tight fit with the hood to get the resevoir high enough for the outlet at the bottom to be safely above the feed line that runs through the firewall.
2) Once #1 is sorted out, I'd like to get the auto trans. brake resevoir so there's no chance of a cap failing and draining my brake fluid out everywhere! Plus, it would just look cleaner.
Has anyone run across a resevoir that's shorter than the Wilwood one? That would make life easier.
