Brake / Clutch Pedal assembly question
brasil
Germany
.. wondering if there are differences between the 2005 to 2014 brake / clutch pedal assemblies . 2005-2009 should be the same .. 2010 up ??
As far as I know the brake booster and the Brake master cylinder are different ( 2005-2009 ) from 2010 on the madter and the reservoir is another .. but what is about the assembly that sits inside / at the firewall .are they different from year to year ? Or can I use a 2008 assembly in my 2010 ? Or even a 2012 ..up to a 2014 ?
I would like to buy a used assembly , because a new one is no longer for sale .. and perhaps I will need such a assembly in the future
Thank you for any input
Juergen
brasil
Germany
… no one here who can tell me something about the differences ( if there are some ) between the 05-09 and 10-14 brake / clutch assemblies ?
GriffX
Rural Germany
Only thing I know is that the later (11+) models have a helper spring on the clutch pedal.
I was interested a bigger brake booster from the GT500 and got some information that the later models have bigger master cylinders and bigger booster. If you go to iihs.net/fsm you can see the differences in part numbers.
So my information is clear as mud.
brasil
Germany
Thank you GriffX
So if I understand you in the correct way , all 05 to 10 assemblies are the same . And if I use a 11-14 assembly there is a helper spring involved … the helper spring should not make a big difference . In my point of you the HS is a nice upgrade .
As long as the mounting points are equal .. everything is good
Hollowdweller
I don’t know if the pedal assembly is the same or not but I do know the 4 bolt pattern on the back of the brake booster is different on the 05-08 & 09-14. I just ordered the 09-14 booster and it didn’t fit correctly.
I was able to get it to fit one way but then the master cylinder bolts didn’t line up correctly. Left me wondering if I just needed to get an 09-14 master cylinder buuuuut I got pissed and just sent everything back and ordered a reman booster from Oriellys
brasil
Germany
05-08 boosters and mastercylinders are different from the 09-14 ones …
That s what I found out .. so the whole assemblies might be different also .
brasil
Germany
Found a 2011 brake / clutch assy .. i also have a new master ( 2010 ) and a new booster (2010 also )
So the next weeks i will put all the part together - and so I can figure out - if the parts work together , or not
Will keep you informed
brasil
Germany
update... 2010 Booster , 2010 Master..go together with 2010-14 Assy. Same bolt pattern.
