ShadowLands
Banned
We have updated our Products page at ShadowLandsRacing.com with our complete line of performance/racing shortblocks. With a selection like this you are sure to find one that fits your budget/performance needs.
Street Sweeper
High performance upgrade for street and strip. Includes new FRPP aluminum block, fully prepped/machined factory cast crankshaft, forged H-beam connecting rods, forged pistons in your choice of compression ratios, file to fit moly ring set, performance main/rod bearings, ARP main studs, machined-balanced-assembled. Rated to 750+ hp.
$3295
Sledgehammer
Similar to our Street Sweeper but we upgrade the crankshaft with a forged steel stock stroke Cobra crankshaft. Rated to 900+ hp.
$3995
The Reaper
Our 298″ stroker shortblock features a new aluminum block, forged steel 3.75″ stroke crankshaft, forged H-beam 6.000″ connecting rods, forged 2618 alloy pistons in either flat top or dished configuration, file to fit moly ring set, performance/race main & rod bearings, ARP main studs, machined-balanced-assembled. Rated to 1000+ hp.
$4395
The Fourth Horseman
When you need to annihilate the competition…you need our 305″ big bore shortblock. Starting with a Ford Racing Boss50 big bore iron block, forged steel stock stroke crankshaft, forged H-beam connecting rods, forged 2618 alloy pistons in your choice of flat top or dished, file to fit moly rings, King race main & rod bearings, and ARP main studs. Machined, balanced, and assembled. Rated to 1000+ hp.
$4995
Devastator
The big inch 4.6 answer. 323 cubic inches of brutal Ford modular power. Utilizing the iron FRPP big bore block, a forged steel 3.75″ stroker crank, forged H-beam rods, forged 2618 alloy flat top or dished pistons, file to fit moly ring set, King race main & rod bearings, and ARP main studs. Machined, balanced, and assembled. Rated to 1000+ hp.
$5995
Upgrades on each of these combinations is available. I-beam rods (lightweight or billet), different compression ratios, standard or stainless ring packages, billet oil pump gears/pump packages. We can also handle your competition engine requirements as well. Please contact us for your specific application and class requirements. Whether you need 2, 3, or 4 valve engines we can handle it. Should you need a pushrod combination ShadowLands has extensive experience with Fords of all sizes....from 289 to over 600+ inches. Even a random Pontiac tossed in as well.
Street Sweeper
$3295
Sledgehammer
$3995
The Reaper
$4395
The Fourth Horseman
$4995
Devastator
$5995
