thump_rrr
You may have an easier time finding Wurth Rost-off which will work just as wellas Kroil.
Pull 'em. The longer you wait the worse it can get.
Tell me about it. I might have seen the damage done to my built engine and saved it in time. Now need a rebuild after 6K on the new block!
Dizzle.. you NEED to check yours now!!! That special trick of our tuner cost someone a new engine and now it maybe two of them if not more. Check yours now!
Your engine is hurt? That sucks man, sorry to hear it if true.
Thanks but Its true.. the good thing is the engine is not totally toast and I can still drive around for a while as long as I dont step on it. The bad news is it will have to be torn down again.
Out here there are not many choices =-/ I should have bought a civic SI and thrown in a 4 inch exhaust tip
