Solenoid Block?
Laga
Chicago
2005 Mustang GT. 57K miles. Car will shift into reverse normally to back out of driveway. But will hang up for a second when shifting into drive. Rev up engine a bit and it will drop into gear. It runs normally once warmed up. I had new TCI torque converter and fluid installed last year and have 2.5K miles on both. From what I read, it’s the solenoid block. Am I right?
07 Boss
Sin City
Could be just a little low on fluid. I might throw a quart or two in there and see if it makes a difference. If not, drain out what you put in. Getting the fluid level right in these things are kinda subjective. I have found that after following the directions that a little extra fluid in there has helped when I had a lag in my 2nd to 3rd shift under low load.
But yes, it could be the solenoid block as well as a number of other issues. Transmissions are not my strong suit and this one is not your average tranny.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
When the solenoid block went on my 2002 explorer (5R55W), I would shift it into reverse and there would be a delay, or sometimes you would shift to drive and there would be a delay so it does sound like the solenoid block could be the problem.
