slowstang06
wiring not being my strong point, probably to the point of phobia... i opted out of the relay kit(ill probably take it to a tuner later to check it out) i have installed the water pump just fine, i grounded the black wire and now i cannot find a 12v switched source to "t-tap" into under the hood. i found a fuse that works but i am not sure how to tap into a fuse.. im interpreting the instructions that i need to utilize a wire
instead of a fuse?
UPDATE: I think I finally figured it all out.. Here are some pics..
Grounded it near the throttle body... (away from the belt)
Wired the pump to a switched fuse (15amp).. i stuck a pin in and had to cut half of it off to fit into the slot with the fuse.. I have a 20amp fuse in the fuse holder
closer look..
instead of a fuse?
closer look..
