Selling a used Steeda Tri-Ax shifter with accompanying bushings (red and black) and bracket to attach at the rear of the shifter housing. This is for the 2011+ Mustangs with the MT-82 Transmission. New they are $249.95, looking to get $175 shipped in the lower 48. Canada, Alaska, or Hawaii we can figure out the shipping costs. I completely disassembled the shifter and re-greased it roughly 1,000 miles ago and the shifter is in perfect working order.
Included pieces are:
Shifter
Red Bushing
Black Bushing
Bracket to hold rear of shifter housing
Spring (not sure if this is the soft or hard spring?) - other is in shifter
Instructions
As you will see in the pictures below, the red bushing has been cut with a razor. I couldn't for the life of me get it off the rear of the shifter housing when I removed the bracket so cut it as close to the top as possible. The cut is deep within the bracket so it should not make any difference once installed. The black bushing has not been cut.
Shifter
Red Bushing
Black Bushing
Instructions
