Nutter281
Hi All,
I'll start another thread with more details in a few weeks when time permits, but I'm planning to take on the infamous coyote into my 2009 s197 GT swaparoo "gulp"
I got a bare long block out of a 2011 GT with 60k miles for a pretty reasonable price but, turns out, guy who sold it to me didn't share the whole truth and I've uncovered some dirty secrets.
Very long story short: previous owner ran a turbo charger with a bad fuel setup, #7 ran lean and blew up, PO replaced the piston with brand new one, reused all the TTY bolts, honed the cylinder without disassembling the crank and other Pistons (shavings in the crank region) and called it a running engine and sold it to me. Of course, I didn't pull TTY head bolts on a running engine when I bought it cause I was planning on running it as is. I found some light granite dust around some of the intake valves that I didn't notice upon purchase inspection which prompted me to just tear down the engine and rebuild it. Found a second piston that was blown and hadn't been replaced. Failure was piston had a broken chunk of metal between the two compression rings - ran way too lean. I called the guy ready to stop by his house and beat the life out of him and he offered to replace the remaining 7 Pistons with new ones. I took the offer since I'm rebuilding it anyway.
The only positive is that the boneheads didn't ever run the engine after they replaced the one blown piston.
Story was too long. OK, so I honed the block out today and found some strange marks in the cylinder of the piston that was blown/replaced. See picture. I'm typing from phone so I can upload more pictures tonight if that helps. After some pretty intense honing with a medium grit stone hone, that V shape is still present along with what appears to be an imprint of the oil ring. I cannot feel these marks whatsoever and definitely don't catch a fingernail but I'm a bit unnerved that they won't disappear after a good hone job. I can't help but wonder if there was some heat stress that may have caused the steel sleeve to fracture beneath the surface or something.
Anybody seen anything like this before on one of these sleeved aluminum blocks?
Thanks,
Austin
Thanks,
Austin
