BMR's went across mine fine, 1/2" to 3/4" clearance. It was originally hammertone, powdered for some pop:
Worth mentioning is that picture was before doing a BMR K-member, when I did the "K" I lost some clearance as I did not get the K that lowered the motor. Hard launches netted enough twist to net a slight touch on the engine cover. I shimmed the brace via a washer and it's fine.
Again, it was only close because of the K member change, running the oem K member I had plenty of room.
Additionally, I had gotten it to fit even with the prochargers air intake in their produced location, but as you will see in the picture, I relocated the Air intake. It's now in the front behind the Cervinis bumpers air slot on the drivers side. I'll see if I can dig up any old pictures of everything before all the changes.
Emay, thanks for the post. The color looks awesome on the parts.
