Supercharger belt slipping
Christenn23
20200521_181926.jpg middle of the pic. There is a clean spot where I wiped it with my finger. The supercharger has less than 1,000 miles, is this excessive amounts of dust?
GriffX
Rural Germany
Try to look at the area around the charger pulley. If you see some rubber dust there the belt slips.
BTW, I had a Gatorback belt for my supercharger and it was worn crazy fast and started to slip. I found that if the typical whine dissapears under high load, something is wrong. So, I use a normal belt again.
