SVT hood clearance
doesn't the stock hood clear the 2.3?
StangPhD
Lumberton, Texas
It does. However, I just got off the line with AM and he put doubts in my mind. I guess I could buy and have a dremel handy.....lol
G.T
Earth
pretty sure it will clear the actual compressor unit..
only problem with the Whipple kit for that engine is the long snout which can have clearance issues with some hoods
AbdullaGT500
Little Rock, AR
It will clear the stock hood, UNLESS you have a 10-rib kit. Then you'll need to do some minor trimming. Also, depending on the pulley size you may need to remove the hood liner.
StangPhD
Lumberton, Texas
I do have the 10 rib kit and my hood liner is removed on the stock hood. I guess cowl hood here I come. I just need to decide what cowl hood to get.....leaning toward Steeda ultralite racing cowl hood.
TotoGT06
SE Wisconsin
I think he does mean the SVT hood, its stock height it looks like but I guess the vents would put that into question
Department Of Boost
Alpha Geek
Cowl hood look fantastic! Too bad they are 100% wrong with the aero/cooling needs of a S197. A cowl hood is the last thing I would put on a S197 unless I never planned on going over 80mph.
Shotokan1509
CT
I though meant this Trufiber one, the 03 cobra style heat extractor which I want badly!
http://www.trufiber.com/2005_2009_Mustang_Fiberglass_A45_Hood_V6_GT_p/tf10024-a45.htm
TRC51
If he is talking about the heat extractor, it should fit. After I got the hood I realized that the lowest parts of the drops are at least as high as the top of the stock hood height. This picture may help.
attachment.php
StangPhD
Lumberton, Texas
The SVT one referenced is the one I was speaking of. I appreciate the input but have decided to fab up my own aluminum extractors.
StangPhD
Lumberton, Texas
I finally got the SVT hood from AM. It is the TruFiber hood. Pre-fit this eve, paint tomorrow and final fitment on Saturday. Pictures to follow.
StangPhD
Lumberton, Texas
It clears a whipple 10 rib kit just fine. Unfortunately, my painter must have painted this in a dust storm. Very disappointing.
