Tapping intake manifold
cyclerick
To measure IATs, can I tap into the rear of the composite GT intake manifold with a 1/8" npt? Is this the best place to measure temp? Do I need to worry about the tap blowing out from the pressure?
fdjizm
Drag Queen
That is part of the MAF, you can probably tap it.
cyclerick
Unfortunately the MAF is downstream from my throttle body in the SC tube whereas the temps in the intake manifold will be higher as it sits on top of the engine. If I wasn't SC'd I wouldn't be worried about it.
irishpwr46
Official Site Vandal
NYC
i doubt your going to be pushing enough boost to blow a threaded sending unit out the back of the intake. make sure wherever you pick, it wont be disturbed by anything leaning/ rubbing against it. and not anywhere that engine torque would cause it to hit the firewall or anything else. and i think the back if the intake would be a suitable spot
Taxman
One foot out the door
DFW FTW
I tapped a runner in my intake with no problems so far. Running 10-11 lbs of boost with no issues.
Taxman
DFW FTW
Tapped the runner underneath so the wires run under the manifold. Everything is out of the way.
cyclerick
Thanks, good advice. I'll be running 11.5 Boost for now. I'm also going to install the manifold heat shield while I'm at it.
