There is no going back...
Vallee
Syracuse, NY
This by far was the most stressful thing I've ever done in my life... My stomach was literally in knots while I did it.. But it turned out aswsome!
20180507_151618.jpg 20180507_154738.jpg 20180507_171334.jpg 20180507_173204.jpg 20180508_191537.jpg
Looks good.
I see you went with the Saleen set up, why not keep the Speed of Sound theme and go with the Triple center set up from them?
I did something similar with a custom SoS set up in my GT years ago, but above the factory cluster, centered about the steering wheel.
redfirepearlgt
Looks nice. Sure glad I wen with the no drill Speed of Sound triple gauge dash pod. That would have made me a nervous wreck!
eighty6gt
It's just a plastic dash pad, I'm sure steve@tasca has them.
travelers
Eastern Pa
Looks good, did you think about running the wires into the defrost duck instead of cutting the dash?
I would think the do make dash covers.
Vallee
Syracuse, NY
The one thing that makes this gauge pod look the best frankly makes it the worst. It looks OEM, sleek and low meaning the gauges are partially nestled into the dash pannel. I modeled it up in CAD and made a template BEFORE I attemped to cut the dash.
20180121_072607.jpg 20180116_180909.jpg 20180507_174610.jpg 20180507_175453.jpg
Pentalab
If you need even more gauges, you can install em into the round vents. The roush vent pods work good, and you also still get air through. Somebody also makes a 2 x gauge pod, that replaces your entire map light assy.
46addict
13726548
Lawrenceville, GA
Have a link to the overhead gauge pod?
Also the pods look good OP. Very OEM looking.
