RedMosesSC
A bit of chatter is a small price to pay for the evil rumble of the cams, however if there was s solution i would get it done.
Both mine and my sons car have the same noise that started after the Hot Rod cam install. Anyone try changing the motor mounts to urethane or solid? That's my plan once I get some cash and time.
i've got the steeda version urethane/solid mounts. it still rattles. and it still rattles with royal purple.
it seems that the only thing that minimizes the noise is to slightly push the shifter handle forward when it's in nuetral and foot off the clutch....just enough to put a little pressure on the linkage. that will make it a little quieter..sometimes...
it's not the throw out bearing. this i know for a fact. i recently replaced my slave/tob, and still have the rattle. or if it is the slave/tob, then it's a design flaw inherent with all oem slaves/tobs
What's the fix?It is backlash in the transmission. Put your car in gear and lift it and support with jackstands. Grab the driveshaft and twist it back and forth. It makes the exact same noise if you twist it back and forth.
What's the fix?
