sheizasosay
Alive
- Joined
- Jun 28, 2011
- Posts
- 1,024
- Reaction score
- 4
Stock (street) category autocross is a piss-poor basis for judging proper wheel to tire widths. Wheel width is limited to OE, while tire sizes are limited only by what you can squeeze on and expect to hold air.
Ultimately, you end up with people running tires for which the minimum recommended wheel width is well over an inch wider than the OE wheel width that you're stuck with. Think 295/xx on 8.5" wheels (but please don't run that combination anywhere except at an autocross event).
FWIW, every car of mine that has ever been autocrossed has run on wheels at least an inch wider than the originals and which weren't any narrower than 1/2" below max recommended for the tires fitted to them. The more heavily modified cars have ended up with wheels 2.5" to 3" wider than the original wheels they came with, and a couple of times that's stepped half an inch past max recommended for a subsequent set of tires.
2008 V6 - the first guideline I ever heard was to choose a wheel width from 1" smaller than the tire's measured tread width to 1" more than the tire's tread width. That was 40+ years ago, and my point is that there's no reason to turn your nose up at wheel widths greater than the measured tread widths of the tires you intend to fit to them.
Norm
Funny. I was just prancing around the interwebz for more info. Trying to find hard data actually; laptimes etc/test....blah blah. Ran across a thread and then a guy that worked at a tire company and then as I scroll down....Norm Peterson lol!! Norm is everywhere.
http://www.thirdgen.org/techboard/wheels-tires/432951-widest-tire-9-5-a.html
