So I'm swapping out my LCAs and noticed this. The right side shock looks like it's leaking. Left side is dry. Is it done for? If so, any advise of where to get a replacement? Thx...
Scramblr;
I'm pretty sure these are limited lifetime warranty (part of the reason I bought mine). You might want to look into a warranty claim,
http://www.stangsuspension.com does sell them individually, and I think Summit does as well.
Alex from my understanding you would need to go through whatever vendor you purchased them from for the warranty. Also these were only used on the street right? Say yes lol.
Could it be that when the shock travels the shock boot is contacting the body and rubbing that spot clean?
If you remove the shock you can compress it with your hands and play with the adjuster. If it is a tiny bit bad you probably won’t be able to tell. But if it smoked you will be able too.
His signature details say he has a Truetrac. There are no clutches, it utilizes a worm gear setup with fluid restriction. With mine I can break the rear end loose and it stays straight as an arrow. It works amazingly well.
ahh, nevermind then, he should unbolt the bottom of the shock and press it up, see if it is leaking. it will move slowly, then as it hits air suddenly collapse. or compare it to the other side. shouldn't take long.
When you spin the tires, do both rear tires pull evenly? You might test it in an empty parking lot and see if both tire marks are equal length. Maybe the TrueTrac isn't working correctly any more? If it isn't, I'd try new fluid first. I've had great luck with Lucas.
if the tru trac isn't working correctly I think he'd know it. there would be many crunching sounds and probably wouldn't move well. I have one in my car too. the way it's designed, it either works or is broke. not much in between like the factory diff
Needs to let me drive it............
