mr. anderson
well learned today that if you purchase the detroit truetrac, the instructions are kinda vague for the spacer, it says to use the spacer with the grove( well they both have a grove, WTF?). I called eaton. they said you want to use the axle spacer that is 21.3x mm and has the deeper groove. while the other spacer which is 22.3x mm. on 05 and up mustang rearends, the larger space should not fit, and if it does fit, it doesn't leave the correct spacing on the axles (they actually both fit in mine). you want a total of .020-.025 per side of axle play. the spacer with the deeper groove is the correct one.
took it for a spin after I got it all installed. feels much better from going from 3.73's to the 3.31's, I now have a 1'st gear that is halfway useful.
the one on the right is correct:
zero'ed out:
axle play spacing, this is both axles moved .0455, right in spec:
zero'ed out:
