Jeremy, you're seeing 10 rise in inlets at 18 psi?
Pump not coming on won't kill anything. Took me 3-5 pulls without my pump before the inlets rose 30 deg at 20psi. Some drag cars don't run pumps at all.
16psi didnt look this last time when I up'd the boost to 18. I have a 4.5" core bar and plate.
The blower type is not why a/w need heat exchangers though. It's because they are mounted in the intake,....so it's in the engine soaking up the heat which gets it hot, not really the air passin thru them.
While this is a factor as well, on a screw blower even when cruising and bypassing the air is still compressing in the blades and creating heat.
