Drain is gravity, crankcase pressure(ensure the vent lines and breather etc are large enough to prevent excess crankcase pressure under boost), windage and oil in the pan will slow the flow of oil back into the pan. Increasing pressure in the center cartridge from the oil feed, causing seal leakings, smoking issues etc. Drain should be 1/2" to 1" from the top on the foward part of the pan, either the front or the front sides where oil doesnt sit.
