mrmonk7663
Do you have a picture by chance? And perhaps the part number for the little k&n filter?
Sweet, thanks guys. Germany is better than the box though Thanks for your service.
I have my catch can on the drivers side the pass. side is left as is. However my questions is do I need a PVC valve in the line from the cam cover to the catch can ? If so should the open side be towards the catch can or the cam cover? I have a PVC valve in line now with the open side towards the catch can, I've been looking at allot of set-ups but I don't see a PVC valve in place.
This is the deal on why Vortech/Paxton puts a PVC in-line when you already have one in the driver side valve cover .
During test they found that the there was so much more sucking or positive vacuum that the intake manifold was looking like a lake of oil. The PVC valve in the valve cover was doing a great job of venting the crank case pressure but was allowing alot of oil to pass by it also ....so they put another PVC in-line to slow the oil vapors going back into the intake manifold while still letting enough crankcase pressure to go buy .
I have a catch can on my drive side and no extra PVC valve like most people have it set up and I'm runing a Noivi 2220 at 15 psi . But thats why my catch can fills up pretty quick because of the huge amount of positive vacuum but at the same time has the metal mesh filtering out 95% of the oil mist vapors ....other side of the hose is always pretty dry and the Tb is spotless.
I hope I understand what you are saying, I have only one pcv valve that is in the line between the cam cover and the catch can.
If you pull your valve cover off there is a pvc inside the cover ..if you have one in line you will have two of them .
Would there be any reason to put an inline pcv coming from the pass side
why is it we see the oily mist out the pass side cover only? you'd think it would be on both sides?
zThe driver side with the pcv restricts flow more and only opens under boost/pressure. At idle it is closed completely and nothing comes out.
