petersonb
Hey guys,
I've found the problem, so that saves us all some time! Lol
I have a VERY loose shifter. See video:
"Loose Shift Knob" Video
And here's where it's loose: Note: Video only shows "side to side" motion; no "front to back" motion shown, but it's still there! (see above video)
"Loose Linkage on Shifter" Video
Now, I have to find the solution. Anyone ever had this problem?
I've found on here where people had a loose shifter, and their solution was simply "Locktite and tighten that bitch down"
But that wont work for me, as far as I can tell. I got under the car and checked all the bolts. All were very tight. In Fact, the one on "Top" that would need to be tightened, can't even be loosened (easily).
The bolt that would presumably need to be tightened is the "top" bolt in these pictures (and is still the "top" bolt when trans is in the car)
NOTE: those pictures are from last time I removed the transmission; it's still in the car right now
I wasn't able to get that bolt loose, and it isn't going to get any tighter either.
I'm fairly certain it's stripped out on that connection.
My Question:
Do I need to replace
(1) The joint that connects the "J" piece to the spline (piece with "top" and "side" bolts.... Rotating in first video) after somehow getting that top bolt loose
(2) The spline which comes out of the transmission (the stationary piece in the first video)
If I have to replace the spline (should be hardened, no?), my guess is that the transmission gets to come out again....
Thanks S197
-Brad
My Question:
Thanks S197
-Brad
