Scott
Jeremy, trust all is going well!
I am picking up my 95723 Kit this evening. For my install I would like to add a Water Trap between the tank inlet and pump. I was hoping I could position the Water Trap right next to the tank without any mounting brackets using the fittings to suspend the Water Trap given that the shipping weight of the tarps are 1 lb.
What Water Trap and fittings do you recommend that are consistent with the 11955 4 Gallon Air Tank and 16380 Compressor provided in the kit?
With your recommended Water Trap and my tank, will the center line of the end inlet of the tank provide enough vertical height to mount the trap (don't know the dimensions of the Water Trap)?
