Stock uca mount of aftermarket? If aftermarket, is it adjustable? I am almost on full soft on my car with the stranges, anything other and it will blow the tires off.
I'ts a J&M adjustable on a BMR UCA mount -1.5* on the angle.Stock uca mount of aftermarket? If aftermarket, is it adjustable? I am almost on full soft on my car with the stranges, anything other and it will blow the tires off.
You adjust the shocks until it hooks. If its not hooking then they are too tight. You could also have too much antisquat. What hole is the uca in the mount?
Oh thank you sir, new adventures!Good luck in the new job!
