What does DTC PO153 mean?
bjbrowder
Gadsden, AL
Ive looked up what the code means, upstream circuit slow response bank no 2. But i dont know what that means.
Both my o2 sensors are fairly new, and they are from Ford ( $75 each ). I replaced them both when i put on the JBA longtubes.
white05gt
Illinois
Did you get a tune for the longtubes? If not, do you have an exhaust leak? If it's neither of those problems, swap o2 sensor from bank one and see if it follows the sensor or stays on bank 2.
tmcolegr
It's All About the Build
Central, FL
If you have never run leaded gasoline it is most likely a tune related issue.
bjbrowder
Gadsden, AL
Yes I have a tune for the long tubes, and I run 93 oct Non Ethanol gas in every tank.
I get that DTC code about once a week.
Fullboogie
King of the Ski - OG Jr.
Houston
Probably from the placement of the rear O2's in the header - further away from the exhaust port.
Aandf1978
M90 SUPPORTER!!
Virginia Beach, VA
It just means that due to the move of the front O2 sensor from the stock manifiold to farther away with the longtubes, it didn't heat up as fast, you may see it every so often when cold, I have seen it once in 2 years, cleared it and it never came back. You are fine, nothing to worry about
Aandf1978
M90 SUPPORTER!!
Virginia Beach, VA
WOULDN'T you know it, a day after commenting, I got the code today. Code cleared, back to running like a champ!!
Thanks for the curse BJBROWDER!! :LMAO:
trbobusa
KY
its a tune issue i got that code once a week after my jba install, bbr sent a different tune and no more codes!
Newman
sumidicsayhuh?
Houston
I've had mine since day one of my long tubes..... Bbr sent me a updated tune and I still get it........ Hope they can get it right when I put the cams in ... I have some faith
