White smoke!! Bad day.
KillrStang
Texas Grown
Bryan, Texas
Well today I went out and the car was driving really well. Boost was coming on quick and felt like a rocket. But I got on the feeder road and got into the throttle and quickly noticed a huge white smoke cloud behind me, got off the gas right away and came to a stop. I let it idle to see if I could hear any metal on metal contact. Non was present but I threw a misfire code for the number 4 cylinder. You could def till it was miss firing and un plugged that coil pack to verify. In my engine bay I noticed quite a bit of oil blow by since I'm only running a breather. So I checked the oil and it seemed a tad low. I also checked my coolant reservoir and it was extremely low. Car wasn't running hot at all and the afr was good when everything happened but slightly rich after it happened tho.
My question is what all should be checked? And if anyone has had a similar experience plz chime in.
I did check the turbo to see if there was any play in the shaft and it seemed normal
lethe
V4g!n@ #er
Everett, Wa
X2 on checking for oil/coolant mix. Hopefully it's a headgasket and not something in the motor itself.
BruceH
BBB Big Bore Boss 322
You blew a head gasket. The mls don't usually go unless uneven torque application was used on the heads or a lot of boost is being pushed through it. If it's high boost then you might as well o ring the block.
BruceH
What's considered high boost Bruce? I'm only running 12 lbs currently. Soon it will be 18-20lbs
12 isn't high. Were your heads and block checked for flatness prior to assembly? I really hope I'm wrong but I'm pretty sure you blew a headgasket. Did you smell a sweet, humid smell of vaporized coolant?
Every time you get on the gas you should see a fog coming out of the tail pipe from now on.
Aandf1978
M90 SUPPORTER!!
Virginia Beach, VA
Everything points to the head gasket, just take the 15 mins drain the oil and you will know right away what's up if that's what it is.
KillrStang
Texas Grown
Bryan, Texas
I'm def draining the oil, tomorrow. I'm also going to pull the plugs for piece of mind. Does autozone rent out bore scopes?
Lito I've checked for leaks on all my coolant lines. I think everyone's right about the head gasket. Like I said she still idled fine. I'm praying I didn't pop a ringland
lito
Caracas, Venezuela
What I meant is, you said the coolant was low, when this happens the coolant system gets pressurized and coolant blows out of the cap, that is what I asked, if there is signs that the coolant spilled out of the reservoir thru the cap.
edit: some ring issues won't be seen thru the scope. Check the plug and see if you load the cylinder if the coolant bubbles, a leakdown test will show a ring issue.
good luck with this and hopefully is something somehow simple.
8306gt
Conroe, Tx
Several things to keep in mind. Water doesn't always go in the oil with a blown head gasket so draining the oil may not tell you anything. There may not be enough water going into the cylinder at idle to notice the burning antifreeze smell however under boost it will likely pressurize the water jacket and push water out of the overflow. I recently blew a head gasket and it never had white smoke from the burning antifreeze nor did water go in the oil. It would push water if any boost was present, and when I shut the engine off it would fill the number 8 cylinder with water because at that point pressure in the cooling system was higher than the cylinder. Best bet is to check the cooling system for exhuast gasses, check compression, and do a leak down to determine what has gone wrong.
KillrStang
Texas Grown
Bryan, Texas
Ok so ill be doing a leak down test sometime this week but I have a slightly different theory since I peaked into the cylinders, and they looked normal for a running engine and not one that has had a headgasket blown ie steam cleaned cylinder walls and pistons...
I currently have a 67 mm comp oil less on my car and my thought is that I blew the turbo not the head gasket.
Makdaddy
I am Dysfunctional
South of Chicago
Are you sure the drain for the turbo didnt get blocked? tooo much crankcase pressure? You mentioned a lot of blow by oil in the engine bay.
If the turbo couldnt drain properly it would make it smoke like biatch on boost
My Bad Didnt see that it was an oil less turbo
KillrStang
Texas Grown
Bryan, Texas
well the drain is in the side of the block, so unless the coolant galley in the block has been compramised that shouldnt be an issue.
pistons are cp2618 iirc
1300 miles on this motor and when this happened i was running 10-12 lbs of boost
19COBRA93
Ford Racing
Clinton, Ut
I'm going to guess it's a ringland/piston issue. I've been there many times, 3 times on CP's. It's a hard pill to swallow. I personally would rather run stock pistons than CP's.
