matt texass
- Joined
- Apr 10, 2007
- Posts
- 1,958
- Reaction score
- 4
Who's got it? How do you like it? Any problems?
I've had mine for 2 years without a single issue. Having the peace of mind knowing the car won't overheat if I toss a belt is worth the price of the pump. Plus if you spend a lot of time a the track it is well worth owning. Nothing like being able to cool down the car in half the time.
Can't say about the timer, but I have a remote switch for my fan inside the car. Turn on key, flip switch, and my eH2O pump, I/C pump and fan all run. It takes about 5 minutes to pull 40 degrees out of the car.i've been thinking of getting one myself but was wondering how to go on about haivng a timer relay for the electric fan that would stay on for a set amount of time once you switch the car off..
thump_rrr & Hawgman - I have read several posts about tapping into a 12V switched source for the w/p relay trigger.
Is there any reason those of us with a Saleen S/C's couldn't tap into the same wire that was already run from the SJB to turn our intercooler pump timer/relay on?
Shouldn't be an issue. Not like the trigger source draws any amperage or anything. Just make sure you get the trigger source in front of any fuses. Would suck for the I/C pump to lock up and blow the fuse and it kill power to your water pump at the same time.
Correct me if I'm wrong but doesn't the main source of 12v + power for the I/C pump have it's own separate fuse? Even if the I/C w/p croaked it should blow the main power fuse that powers the I/C pump - not the fuse for the timer/relay trigger wire from the SJB. That's why I thought this would be the perfect 12v + source of switched power for the Meziere w/p relay as well. Both relays draw minimal current.
PS: Thanks Hawgman & thump_rrr for your PMs.
