Winter Project (engine bay cleanup) - have some questions?
killermustang
New Brunswick,Canada
Well my car is stored for the winter, so i started gathering parts to put on it in the fall and I had a few question that im not sure about.
1. I bought a battery relocation kit, and im looking in to buying a second engine wiring harness to do a wire tuck - (?) will a engine wiring harness out of an automatic be the same/fit as a 5 speed standard tranny?
2. Since im replacing all the pulleys ie. crank, idlers(3), belt tensioner, water pump (?) can the timing cover and valve covers come off without draining the oil
3. will a 06 tstat fit in a 08 coolant crossover assembly
sorry for the long post, end result should look a little better than this + painted timing cover/valve cover w/ billet pulleys
looking forward to your expertise
