Yup, it got one. I set it lower than in the tune. The two step is an ajustable rev limiter.
It has a primary rev limiter also. The clutch tells the wot box which rpm to limit at. That's the adjustable part. Clutch out, main rpm rev limit. Clutch in, second rpm limit/two step. You can see the rev limiter in the center of the screen shot. It's set to 6k, but turned off.Only when the clutch is fully engaged.
Ann, ok never realized, thanks D
The pain in the ass lockout is activated, too lol
Well, when I drive I don't just floor it to get the rpms up. I come in with the rpms high and start to bang the turbo, but for the shortest period of time possible. If the lock out is on it's kinda all or nothin'. And the pedal isn't always down all the way. Depending on how much the track will take you can control boost w the pedal. Lockout and pedal threshold off you can do it how ever you want. Only need the clutch down to get the two step to work.I guess I always drop back to idle at the line anyway, you guys hold your rpms the whole time even before you're staged? lol so confused.
