Wtb shortblock
calispecial08
Let me know what you guys have, I am looking for either a stock shortblock or just the bare block, also interested in teksid blocks
BruceH
BBB Big Bore Boss 322
I have a block. It's from an Explorer. The main difference between this block and a 3v Mustang block is this one has more aluminum to reduce nvh.
I want what I have into it plus shipping. I've shipped blocks before for around $100 fedex ground but it would depend on where you are.
I'd need $450 + shipping. I know it's alot but if I ever need a block it will cost at least that much to replace it. I can also ship the crank that came with it for shipping charges only. It needs a regrind and cleaning.
Edit: Another pic.
calispecial08
So would I need to do anything else different with that block? Are the mounts and everything the same?
BruceH
The mounts are the same. The only thing you would have to do is put a 1/8 npt plug in one of your front cover holes. The bores are still stock size but the crosshatches are almost gone. It uses the same parts as a 3v.
Hang tight though. Chances are that someone will offer you a block for less than what I did, that's how it usually goes. I'll get some more in depth pics of the bearing journals and underside of the block if you would like.
calispecial08
Alright man yeah that sounds good! Just post the pics up in here when you get them.
BruceH
calispecial08. Your box is full and I can't answer your pm until some space is cleared.
