X-Charger setup for ‘05-10 V6
Lightningtruck
S197 Newb
New Kent, Virginia
As the title says, I have a very nice used X-Charger setup for a 2005-10 4.0L. Comes with what you see in the pics, there is NO tuner. Injectors are 39lb, MAF is 84mm. Not pictured, but included are the special coil pack bracket, and also the thermostat housing water neck. Kit is missing the EGR tube, but you can bend one up out of an original. Blower has a 2.8” pulley, for 10-11lbs of boost.
I did not personally get to run this kit, but can tell you that it looks real nice, blower turns silky smooth and there is no chipping or wear on rotors. The only thing I see is the cold air box brackets got slightly tweaked (but could easily be bent back in place....it’s just sheet metal.)
Anyway, I just bought a newer car before I had a chance to install this, so it’s up for grabs now. Price is $2500 plus shipping, and that’s a firm bottom dollar number. Will ship when money order clears, or I would much prefer a face-to-face CASH transaction. I will be at Ford Carlisle on Friday, June 1st and can deliver there. I’m also going to be travelling between Richmond, VA and New Jersey this Saturday (May 19) and could meet up along the way. Just throwing that out there. Let me know if you have questions or want better pics.
Here are the pics:
SlowV6
Do you have any contact info I can reach you at? Maybe facebook or anything? Thank you.
Lightningtruck
S197 Newb
New Kent, Virginia
For those that have asked, best I can tell is that this is kit# XS5556M/2.8, commonly called the “Hi-Po” kit. Hope that helps.
If any of y’all know what/if the casting numbers mean anything, I can get those for you. There is also a serial number label on the side of the blower also.
Thanks,
Kevin
Lightningtruck
S197 Newb
New Kent, Virginia
Loading up for Carlisle. Supercharger setup will be with us. I’ll post up our location when we get set up if you want to take a look.
Thanks,
Kevin
