46addict
13726548
What cam are you using now?I will check out Lito if I go to a serious cam one day, he is the man! for now I use an emmision tune with the 02's on and the non foulers do the trick, then back my race tune for 2 years.![]()
You will be happy with that Exedy. I have a Mach 500 in mine and I have no complaints in the way it holds power. It almost always won't let me into reverse though unless I go into 5th first, and sometimes locks me out of 1st. I don't know if that's from the shifter I'm using or the stock clutch line/slave cylinder not disengaging the clutch properly.I hear that is a good one as well! I have a single disc. I had purchased an exedy mach 400 in preparation to swap my clutch last year.
I called up exedy and was able to get a part number for the same clutch disc but in 26 spline.
Next go around I will upgrade to a McCleod. Seems quite a bit notchy getting into first/reverse from a stop like the disc is a bit fat... but I will wait to put some miles on it and see if it lessens.
