Brakes or shocks/struts
Norm Peterson
corner barstool sitter
RIP - You will be missed
That's because you haven't gone fla_tout. :D
Almost as close as I can, though. Something like 315-ish HP at the crank is letting me get right at redline in 4th down the main straights at either of the courses at NJMP (my home track), this being about 125 mph, with virtually nothing left. Acceleration is basically flat-lined (at barely +0.1g immediately before hitting the brakes). :shrug:
Actually, I don't think that NJMP is all that tough on brakes, but I did manage to crack all 8 of the XP8 pads (heat-checked the front rotors), and all four of the front XP10's after that. Right on the edge of overdriving them and I took the hints.
In the words of Carroll Smith, "...sliding caliper, which I consider to be a crime against nature."
Don't know when that was written or where pad technology stood at the time, but since I'm not getting fade or appreciable unequal or taper wear I really can't complain even though the fronts are only 2-piston sliders.
2Fass240us
..I'm not getting fade or appreciable unequal or taper wear I really can't complain even though the fronts are only 2-piston sliders.
I experienced uneven wear (likely due to caliper spread), crumbling pistons, and cracked rotors on my '07. All of the above issues were realized WITH 3" cooling ducts on the car and 2011+ Mustang GT rotors. I'm swapping to '07-'12 GT500 rotors, Wilwoods, and custom brackets for my '14, and trying to increase spindle-end cooling effectiveness.
One of the main tracks I run (CMP) is very brake intensive, but VIR is far less so.
TGR96
el blanco nino
Huntsville, AL
Just throwing another option out there for you, OP...for your $1500, if you shop around on the forums, you should be able to get a decent set of aftermarket dampers, springs, and even some GT500 take off 4 pot Brembos. That would handle your modest track day/autoX demands. And lets face it, the Brembos look much nicer peeking through your wheel spokes than the stock calipers. :thumb:
I got my gently used Tokico d-Specs, H&R Supersport Springs, GT500 strut mounts (bought those new), and take off GT500 Brembos for right around your $1500 target. It may not be the sexiest combo out there, but it rides good, handles 100X better than stock, and it works for me. Plus I didn't have to drop major coin on new parts.
2Fass240us
This idea seems like a winner.*
*As long as the dampers are Bilsteins. :)
Speedboosted
Found missing cylinders
PNW
Well said Andy. I was able to pick up my Bilstein's for much less than people seem to think they cost. And not worn out used junk either.
