Rear Springs 1" Lower
rocknrod
China Spring, TX
Is there a spring set that will lower the rear of my 05 GT just 1". The ones I looked at go either .5" (Rousch) or 1.5" or even more. I know I will have to get an adjustable panhard bar. Just looking for the spring set.
What do you think?
Samos3
St. Louis
I have the Ford P springs. On stock 18" wheels.20230226_173537.jpg20230226_173551.jpgDon't forget the Ford Performance bumpers.
GriffX
Calculation of the wheel offset according to the panhard bar. Federweg: Lowering, Versatz: Offset.
The offset according to the flexibility to the rubber bushings is more than the geometry of the panhard.
The full suspension travel is 9 cm in and 10 cm out, so the axle moves 4 mm to the driver side at full in and 5 mm at full out.
(this is knowledge from 500 B.C. Greek Thales from Milet, It is hard to preserve knowledge and freedom much harder)
Samos3
St. Louis
Definitely get the adjustable panhard bar. I think there was a visible 3/8" shift to one side. That was with the 235 tires. The 255s add another 5/16"-3/8" to each side of the tire. So that would emphasize the shift.
DieHarder
I have a set (F/R) of new FRPP "P" springs in a box. Had them on for 2 weeks. $150 + the ride if you're interested
AHaze
Edmonton, AB
Do the trigonometry (or read post #6) and you'll see that's not possible. The lateral axle shift over the entire suspension travel is less than 1/4". The shift caused by lowering springs is significantly less than that.
Samos3
St. Louis
Trig is not my thing, so I will have to trust the expertise of others.
I
GriffX
You can do an easy experiment, take a 3 ft 5 long stick, put it on a table and lift one end to watch the offset.
The fender wheel distance is a function of the panhard angle, the flexibility of the bushings and the wheel weight.
I think if you want to adjust the panhard length you must go to an alignment 4 post lift and put 75kg on the driver seat.
No idea if this makes any difference in driving. At least the PU bushings of the new panhard will do something.
JC SSP
FL
I used an adjustable Panhard more for the factor rear being slightly off center-line (if I remember stock was 1/8 more on the passenger side than the driver?) than my concerns with being too low.
rocknrod
China Spring, TX
Wheel well to ground level measurement in the rear is 29.5" with a opening gap of 3-1/4" from the top of the tire to the wheel opening.
In the font it's 28" with a gap of 1-3/4".
JC SSP
FL
With the Ford "P" Springs I am at 28" Rear and 27.75" Front.
You might want to just put in the rear springs and see if it levels out... but every car will be different.
This is what my car looks like... Daughter is driving... LOL
