Yah, if you look at my 9.8 slip I went 112mph with a 6.300 and if you were spraying in 2nd you should be even faster than that. What was your best mph in the 1/8th before your current setup w/ spray?Hey Mark thanks, yea I know the car has more in it . The converter not being tight enough could be hurting the ET a little . Went a 6.220 @ 108 in the 1/8th . It should be more like 112.
Will keep trying different tranny tunes to see if I can get it into the 40s or 50s.
Pete
