BruceH
BBB Big Bore Boss 322
He should be easily over 600 with the 5.0
600+rwhp at 9 psi with a 2.3 whipple?
I would have to disagree with this on 9 psi on a 2.3 and pump gas.
HP = TQ @ 5252 rpm.
That dyno graph is not real, or there was an error on the dyno.
That dyno graph is full of fail. HP and torque will always cross at 5250 rpm's and that graph has them crossing above 6000 rpm's. I would have thought it would be making more torque too.
They aren't crossing at 5250 because the hp and tq are scaled differently.
Wrong and wrong
HP = TQ x RPM / 5252
The graph IS real; HP and TQ are = @ 5252 RPM, they are just scaled differently.
See above...
5252
this is what I get for not reading every post... I still feel he should be making more power with that AF.
Seer.
When you say "that AF", are you referring to the dyno reading that was read from the tail pipe or are you referring to my wideband gauge that reads 11.00-11.15 at WOT pulls??
I'm talking about your wideband. Typically dynos are off.
How much do you think he should be making?
HP and TQ will always cross at 5252, hence my original statement, HP = TQ @ 5252
Read my following comments when I noticed the scaling. Put the gun back in the holster bud
For comparison sake my 11 GT with the whipple and 9 psi made 538 rwhp through the GT 500 tb and stock exhaust and 15 degrees of timing.
You arent far off.
Im almost to 600 now with the L&M tb and full exhaust at the same psi and same tune.
You arent far off.
how is your drivability with the L&M any quirks?
where was your tq?
