Anyone have one on Camber Bolts?
J.Cagle
Dennis Kansas
Just watched that video. I am by no means a mechanic, but I dont see what the washer even does. The washers that came with mine, I am pretty sure, didnt even have an offset hole or anything. I wish someone would chime in with some pics or sumthin. Its buggin me now that I dont have the washers on mine.
Daniel Day
Resident psychopath
Newnan, GA
The washer has that tab(the small one not the large one) on it and it holds the bolt to one side or the other. The larger tab on the side of the washer is there so you know which way to place the washer. The tab towards the car for positive camber correction and away from the car for negative camber correction. If you don't have it on there than you probably don't have your camber corrected. Without the washer it is basically the same thing as the stock bolt.
