2005Redfire6
Hey guys, I have made approximately 15 passes in my car and due to traction issues/shifting issues (shifting issues are fixed) my PB is a 13.07. With the mods/weight of the car I should be low low in the 12s. I have experimented with tire PSI as low as 12-16 psi., I have also experimented with different shock settings suggested by some guys on here in other threads. Here are some details on the car:
- 2005 w/ approx. 350+ whp
- 5 speed
- Weighs 3130 w/o driver
Current setup:
BMR LCA
BMR Relocation brackets (LCAs are in the 2nd hole from the bottom)
BMR Adjustable UCA
BMR Adjustable PHB
BMR PHB Support
Strange 10 way F/R Shocks
Stock V6 springs
MT ET Streets 275/60/15
4.10 gears
No rear or front sway bar
The car has more mods obviously, just thought those were the only real important ones.
I have launched the car as low as 3700 or so and it just blows the tires off launching off the 2-step. I am thinking about going to a slick and I am trying to determine if I should go with a 26" or 28" tall tire. Currently I am shifting around 6800-6900 and the car is hitting the 7000 limiter right around the 1300 ft mark. in 3rd gear. Would it be wise to go to a 26" tire? Which slick would you guys suggest? Let me know if you have any more questions.
Edit: my fastest 60' is a mid 1.8 or so will have to check to verify. I have a line lock and feel as if I am doing a sufficient burnout.
- 5 speed
Current setup:
BMR LCA
BMR Adjustable UCA
BMR Adjustable PHB
BMR PHB Support
Stock V6 springs
4.10 gears
