Well, for myself, thinking hard just comes naturally to me. It's in my nature: I'm driven to understand not just how things work, but
why. It's at the core of my being. Can't be helped.
Yep. One of the biggest reasons I started with the stock suspension and didn't change a thing save for wheels and tires is that I wanted to get a feel for how the car behaves by default. I figured that you can't really fix something if you don't know what's broken first.
I've had no problem getting the car in stock form to turn in (it does so a bit easier with the Konis and camber plates, though). I'm frankly not at all unhappy with the
performance of the stock suspension. My main complaint was the ride harshness, which the Konis fix nicely, and the tendency to eat the outside edges of the front tires (but, in my case, that happens relatively slowly because, firstly, I'm running 280 treadwear tires and, secondly, I don't push the car as hard as some except at autocross-format events like the Evolution driving school), which camber plates fix.
It's entirely possible, and indeed more likely than not at this point, that I won't want to change anything else from this point forward. We'll see. It'll depend on whether or not I run into what I regard as a major shortcoming in the suspension sometime in the future. Based on what I felt from the car at the Evolution driving school, it may be quite a while before that happens.
One thing that is a bit different about me is that unlike a lot of the people here, having the suspension move around under me doesn't bother me. It's what the suspension is
for. It's supposed to move around so as to keep the tires planted firmly under lots of different conditions. Similarly, the nose dive under braking hasn't bothered me either, probably because when I'm braking, all my attention is on my turn in point, the apex, and/or the track-out point, and I tend not to notice what I'm not focused on.
What if they trail brake into the corner?
I've found with mine that if I overdrive into a corner, lifting the throttle will neutralize the push nicely (more so now than before) and brushing the brakes will easily do that and may even make the rear come out some.
What's different about a Watts link in this respect?
Not only does it matter, I'd argue that it matters more than anything else!
The setup just determines how the car behaves for the driver with his driving style. The driver determines what the car actually does within its behavioral limits.
I've mentioned it before elsewhere in this forum, but I'll say it again here. I like the fact that the suspension covers everything from understeer, through neutrality, through oversteer, and that you can control which of those regimes you're in through your inputs. Seems to me that a car that is controllable in that way is highly flexible, one that you can make dance around the corners. There's something special about that.
Lots of experience helps for that. Not only does it inform you of what works and what doesn't, it also informs you of where to start looking when you identify a problem.
You'll never see me arguing that experience doesn't matter. It matters
a lot. And, in fact, experience is the ultimate litmus test of any theoretical model. The scientific method has experience, in the form of experimentation, baked into its foundation, as you use experimentation to verify or disprove the predictions made by the model.
But, especially for those of us who don't have the kind of experience you have, having a model helps as well. It helps us to make sense of what we're experiencing, if nothing else.
This is very true. Not only that, but that kind of discussion can reveal what your model hasn't been accounting for. It can help you refine your model, make it closer to real-life than it would be otherwise. It's one of the major benefits of a forum like this.
The value of a forum like this is not to be underestimated.
